possible stupid question on 22.5s
abescustoms avatar
abescustoms
i found a guy here in northern cali they has four semi wheels 22.5 and selling them to me for 400.00 all four no tires but they are 22.5x8.25 and they are stud piloted will these wheels work on my dually with the adapters or do they have to be hub piloted, what tread pitch are the adapteor studs? also and what s the hub ring measurement to measure these ones
ec_dually avatar
ec_dually
ifia m not mistaken you need hub piloted
huskerdually avatar
huskerdually
If they are used that isn't a very good price either.
lockone avatar
lockone
You need Hub Piloted. Stud piloted wheels have a larger hub bore than the Hub piloted wheels.
huskerdually avatar
huskerdually
How can you tell btw the 2 by lookin. I found some junk ones I want to use for mock up.
huskerdually avatar
huskerdually
Oh and how much are adapters again.
lockone avatar
lockone
Hub Piloted wheels have a hole for the studs that is a cylinder ( the same diameter from front to back).
Stud Piloted wheels have a beveled edge on the holes for the lug studs so that the conical seat on the lug nuts can center the wheel.
huskerdually avatar
huskerdually
Thanks a bunch.
abescustoms avatar
abescustoms
thanks i had a feeling the hub bores are diffrent and that it was going to vibrate if i was to get them. what about on the single wheel for the rear is a accurate wheell 22.5x12 or 13 or what
watahyahknow avatar
watahyahknow
so the stud piloted wheels have a bigger centerhole , do they have a different boltspacing allso?
