pop-up gas cap
20 following
texmextukin@yahoo.com's avatar
pop-up gas cap
Texmextukin's avatar
Texmextukin
I was just wondering, would a chopper gas cap cause me to fail inspection?
Rambo
mabey if your inspection station does gas cap pressure tests like they do in MA
splitdecision's avatar
splitdecision
I can't speak for Texas either but I know you can't pass with one here in Georgia because they do the gas cap pressure test here also.
crazygenius13's avatar
crazygenius13
same here in CA. get one with a check valve built into it, if they even make it.
thacru78's avatar
thacru78
In Texas it depends on if you bring the guy the right beer. If he's a Bud Light guy and you bring him Miller Light, maybe you'll fail. But most just want it cold and in the 12 packs range. then you can pass with almost anything. LOL
Texmextukin
^^^^I understand what your sayin man.Beer helps fix everything, dont it.(well most of the time)
AVTekk's avatar
AVTekk
those gas caps will also throw up an EVAP code in most vehicles, they usually have vents in them, and the EVAP system needs it to be closed to conduct tests. you can get them non-vented, that should work but you cant use them if you DONT have evap still hooked up, and theyll also build pressure when the truck sits in the sun.
karathos's avatar
karathos
I live in Elpaso, After moving from PA to Texas they made me do emissions, I have a harley fatboy gascap, I just bought a actory cap from autozone and handed it to the inspector. Passed with flying colors. Give it a shot. Might work for you.
okcderek's avatar
okcderek
So I am confused... I have a 99 Chevy crew cab dually and a 93 Caprice wagon and was wanting to put one of those flush mount gas caps on them. Will it throw a check engine light if I switch to one of these? And is it going to cause problems w/ my gas tank swelling...?
Dj-Chuy
Big Dee, It probably will on the Dually, but not the caprice. I changed it on my 95 GMC Fullsize and nothing came on.
