underslung frame question
draggingtb@yahoo.com's avatar
draggingtb's avatar
draggingtb
I've been hearing more about underslung frames, and they look interesting to me. clean look, i like the idea of not having a notch above your axle. but I can't see any way to get good lift with them. so basically, why do people do them? is there any actual advantages to them? or is it just a personal preference deal?
X
XoticObessionS
One way to get lift is to make ur setup a true cantilever setup or another way is to notch the frame on the top side for where the frame would hit the axle... But it depends on if u really care bout how much lift u get in the rear or not...
granth
it can only get as much lift as the axle will let it.... it will hit it sooner or later.
never seen the point in crazy lift anyways though, so I would be down for one!
MIDWEST DRAGFEST's avatar
MIDWEST DRAGFEST
it will get you driveable. with the frame setup that way you usually only get 1:1 lift.
SkittDattle's avatar
SkittDattle
Just remember, bigger wheels = more room for lift!! Go big!!
Gump1986
couple of things to think about - you lift will be limited by the size of your wheels. if you are running big wheels, this would work better.
building a frame this way could also make it hard to setup a 4 link correctly since all of the frame is underneath the axle, unlike a conventional notch setup where you have mounting points above and below the axle to mount the link bars. i know it can be done correctly, but it will not be as easy.
SkittDattle
Originally posted by Gump1986
couple of things to think about - you lift will be limited by the size of your wheels. if you are running big wheels, this would work better. Did I not just say this?
nryota's avatar
nryota
yeah got a race car buddy he showed me these types of frame setups. thought about one for years. wouldnt really be conventional but more all show.
draggingtb's avatar
draggingtb
well, i wasn't really planning on building one. the thought of them intrigued me. i like the look. but i was more of just wondering if the set up has any actual purpose or any advantages other than visual.
granth
more metal to drag
