nitrogen setup
hardbody_188@yahoo.com's avatar
nitrogen setup
hardbody88's avatar
hardbody88
out of all of my friends i am probably the most trigger haappy person in the group so my compressor is naturally running about 90% of the time. i want to convert over to a nitrogen setup while still using my compresor and tanks when ive shot all my load, i know that i need a regulator and a tank but what are the little things that im missing like upgraded lines or a scoop of rice with gravy on the macaroni salad im just wanting to figure out the little things first
coptic120
Tank, regulator, brackets, hose, fittings, and i would put a ball valve for a shut off between the bottle and tank.
snydecat's avatar
snydecat
i have a setup if you you be interested. i have the tank, regulator, brackets, a hose ther goes from the regulator to tank, i have everything. you just let me know we might be able to work out somethin.
bowtied's avatar
bowtied
i've got a big bottle takes up the width of the inside of my bed on my 89 chevy swb. I just got a home built bracket (compliments of phat phabrikationz) and some ratchet straps holden it down. Along with about 1-2 feet of airline that plumbs into a tee fitting that goes to the tank. I've only got one 5 gallon 4 port tank as a backup and i run the nitrogen thru it and the lines are plumbed to it. it was easy i just got an extra tee fitting and threw it together. (well i didn't the guy that installed the airride did it) Hope that helps. I could get pictures of it it you need. Just pm me and let me know. Good luck.
