popping though stereo when hitting the switches?
blazins10@msn.com's avatar
blazins10's avatar
blazins10
Edited: 7/22/2007 8:01:14 PM by blazins10
what is causing this ? its really annoying all conections are good ,have another bagged car without this issue?
thanks in advance
mike
olskoolpup
it has something to do where the power and ground for the swithes are pulled from. some vehicles just do wierd things if you tap into the factory wiring for power or ground.
id first try running a new groud for the switches to the chassis, that is if its
currently tied into the harness.
greenranger 23's avatar
greenranger 23
thanks i have the same problem
Twisted Galant's avatar
Twisted Galant
check your grounds!!!! That prmarly is the cuse of all noises in audio. That and running Patch cables along side power wires int the vehicle. Also try to get cable from the main 12 volt wire going to the ignition switch
phillip's avatar
phillip
my car was doing that really bad i had a bad ground trace inside he radio good luck
cantlooswit22s's avatar
cantlooswit22s
that will normally be the problem..check yuor ground..i will usualy run all new wires to avoid lil things like this..
draggin97
I have the same problem, i have to positive going to the positive terminal of the battery and the negative grounded to the frame. I can not figure it out.
NCI Grand Am's avatar
NCI Grand Am
GROUND LOOP... Check all ur Grounds try grounding the amp or if u arent running an amp ground your Deck to the Body
