how to wire switches
BigCrick1111@hotmail.com's avatar
BigCrick11111's avatar
BigCrick11111
i have a ten switch box that im no longer using im just goin to use two switches for the front and back now and i was wondering if anyone had a wiring diagram ive never wired switches and i dont want to fuck anything up so any help is greatly appreciated
dflated19
if u just want front and bak you still have to wire each indivual switch...you have a front and back switch that is build to open the 2 individual valves you want at the same time
BigCrick11111
i just need to know how to wire one switch do i have a 12v to the off position and one wire to the fill and one to the dump
jland1980's avatar
jland1980
Edited: 6/30/2007 11:50:26 AM by jland1980
the switch has 3 prongs you take 12 v to the center prong, the other two prongs are for your vlves, one for the fill one or the dump. and one of the leads on your valves gets grounded to the frame.one switch for front one switch for back!
Sprk Sho's avatar
Sprk Sho
If you want to do front and back you only need two 6 prong switches. The center prongs are the power and the top and bottom would run to each individual valve you want to control. Fact of the day is that when you hit a switch up it's connecting to the bottom prong and when you hit down it connects to the top prong so make sure you know which way you swich is going to be facing then you can wire it accordingly. I know that sounds confusing but i hope it helped.
nryota's avatar
nryota
^^^ Paul how long since you have had to think about that...?
oldskool84's avatar
oldskool84
at first you don't succeed try, try again. Paul gave the best wiring class not much to add.
BigCrick11111
thanks guys i just got it done and they work perfect thanks fellas
nryota's avatar
nryota
yeah but pauls truck hasnt moved in ummm...hold on need to take my shoes off...
