Where to get custom brake lines made?
clenzer72
I need to have some front brake lines made to go from a Ford Ranger to a Mustang Cobra Caliper....where should i get this done?I would love to find someone local in the CA Bay Area but i'm not having any luck....
Advise?
MIDWEST DRAGFEST's avatar
MIDWEST DRAGFEST
orielly's
TwistedMinis's avatar
TwistedMinis
Doug do you need a flex line going from a hardline to the caliper? Can't you just get a stock Mustang Cobra flex line? If the ftting on the hardline is wrong it can be changed and reflaired.
clenzer72
i never thought of changing the fitting on the truck. I have a set of cobra brake lines...that might be the best route to go.
TwistedMinis
Thats how I did mine. My hardlines have metric fittings on one end and standard on the other to fit the GM calipers.
maz duh's avatar
maz duh
I have got custom brake lines made at my local circle track shop before. Stainless steel braided with the fittings I needed to make the setup I was doing work. Circle track shops have alot of cool and hard to find items that can be used in truck building. For example the last time I went I saw that they had a 3/8 ported CO2 regulator that was designed to run air tools straight off of a CO2 tank while fixing a car in the pits. Looked like nthe perfect reg. to keep the air tanks in my truck topped off. Lots of laser cut gussets and heim joints,bushings etc. the last time I was in. Worth a look if you have one nearby to you. Sorry to hijack the thread btw.
clenzer72
Thanks man, but no circle tracks around here.
Anyone know that size of these brake fittings that come off the frame?
low99maz's avatar
low99maz
The local parker store here just started making brake lines, try them! Truck is looking good by the way
mindlissmetalfab's avatar
mindlissmetalfab
Anyone who makes hydraulic lines should be able to do it. We have had a couple sets made for bagged rangers. I actually have an extra set but it would have the ranger fittings on each end.
