hay i just took off my gas neck from my 2000 s-10 i want to shorten it i washed it all out and and i put it in a bucket od soapy water . i was wondering how long i should keep it in the buck of water for? dofore i can cut it and re tack the fill cap on??? thanks mike...
riceeter85
anybody?
keele
Edited: 5/31/2007 3:07:07 PM by Layin Low 4 Life
Now. Shouldn't have much to worry about. I took mine off and just started cutting on it. If I understand you right its just the neck (metal) and its not still connected to the gas tank so even if ya do get a spark its not gonna blow up or burn that much
riceeter85
ya its off the truck alright thanks ill go start cutting it right now...
keele
Ha alright, might have a rag next to you just in case it catches fire a lil but you'll be fine
draggin97
sounds like you should be alright, just keep a blow gun at close reach.
AVTekk
it wont catch fire, its just a filler neck. just make sure you dont melt the plastic ball valve thing in it that keeps gas from spilling out in a rollover.
