the back of my truck lifts way too fast
18 following
capcomfan19 avatar
capcomfan19
ok 94 fullsize chevy 2600 firestones over axel. 1/2" line 1/2" valves. tap the switch the wheels come off the ground. not my style i feel like itll break my notch off after awhile.
i could use 2 of those fill controlers from suicidedoors.com but thats $50. i hope i could fix it cheaper.
i was thinking of running 3/8" or 1/4" line back to the bags. leaning towards the 1/4"..
what do you think?
mr donut avatar
mr donut
how much psi are you running? if it is to fast change to a 3/8 valve
sandog avatar
sandog
Ricky from www.whynotfab.com sold me some 1/2 adjustable ball valves for like 15 bucks, adjust the flow with a turn valve manually, and no more wheels come off the ground. Problem solved.
capcomfan19 avatar
capcomfan19
im running a 145psi pressure switch. but if my tanks are low enough not to lift the front at all itll still launch the back off the ground. i might run 3/8 valves but i was hoping that i could fix it with smaller line.
simple-pleasurez avatar
simple-pleasurez
what kind of valves are you running?
mr donut avatar
mr donut
if you step the fittings down to a smaller line it should slow down the rear.
dirkbelt avatar
dirkbelt
that would be the cheapest fix!!!!!!!run 1/4" line
pewter2000 avatar
pewter2000
suicidedoors.com has the adjustable fittings that go in the lift or dump port.i never tried the lift fittings,but i have them on my dump valves and they work real good!
NO AFFILIATION avatar
NO AFFILIATION
buy you some brass male caps from home depot and drill it out lil at a time,till you like it.
TwistedMinis avatar
TwistedMinis
Ball valves, Lowes, $10.
