ok i am at the point to decide which compresor i wana go with ,,should i go with an oasis or an engine drivin i have a 93 pre-taco and im not sure what type of engine drivin will fit or if i can use a an ac compreser insteed Any help would be great thanks
MD
mr donut
i have had both i like both. with the oasis you better be ready to upgrade the charging system. it takes alot of juice. i am running a 14 volt set up with an upgraded alternator. engine driven just bolt it up and go. just hope the truck starts when you need air. that is the only draw back to edc.
dragginsteel67
Easy solution to the tough engine start thing, just run a switch/relay combo on the dash to interrupt the compressor power as well as your pressure switch/relay at the tank. I have an engine driven too and yeah, with the compressor engaged it's a tough turn over for the engine.
get twisted
the oasis is an EDC just has a winch motor srtapped to it if you have the room run the EDC if not do the oasis
SSM-Webmaster
EDC is the way to go... with an oasis the cost of the actual compressor let alone upgrading the charging system is going to really pricey. you can pick up a Edc Pump from the junk yard for under $40 check out minitruckinweb.com and under the forums there is info about my truck which we did and EDC with Keeping all Factory A/C and power steering there shopuld also be a tech article up there soon as well if your interested
SSM-Webmaster
the right type of pump for that truck is a york 210 and theres all sorts of parts and info for them on kilby enterprises website
