Did a engine swap on the Luv and havin a lil trouble thinkin up a way to mount the new aluminum radiator, its bigger than the stock. You guys have any pics or suggestions? Thanks!
suckafree
modify the radiator support and sink it in there with custom mounts. Dont forget to put some rubber in there to keep it from rubbing the metal.
unusualfabrication
Edited: 5/29/2007 12:17:01 PM by laynframe90
I ended up building a new core support out of 1x1 square tubing. The radiator sits on 2 rubber bushings that I took off a strut rod. For me it was easier to make a new core support so I could put everything where I wanted it.
