Mini Truckin General
quicky question
quicky question
General Discussions
quicky question
CHOSN1
Have a quick question. Is this the load equalizer that is for the turn signal?
whynotfab
looks like a bomb LOL
crazygenius13
or a piece of gum wrapper wrapped around some wires
CL
Cruz Lo
Those are resistors. To reduce voltage in a circuit.
That type is typicaly used for higher wattage (15 to 25 watts). They are not found in factory wiring for newer cars/trucks.
You must have lights or something else that needs less than 12V. Like LED's or something?
CHOSN1
^^ its wired into my led's
CL
Cruz Lo
Edited: 5/25/2007 1:24:43 PM by Cruz Lo
OK then that's what they are for.
Not all LED's can take 12 volts. so those resistors are there is yours get the correct voltage.
OR some of your leds are less bright than others (like running lights are less bright than brake lights/turn signals)
Voltage = resistance (of the reistor) multiplied by current (amp draw) of the LED's
Hope that helps.
CHOSN1
thank you ^^^
Lowlife Video
CutSceneRyan
11 mo
CutSceneRyan
11 mo
mini chopper frame plans
Krazzypaul
21
Krazzypaul
bomber Seats
Godfather
68
Godfather
Dancing Bed
Dubtruk
Dubtruk
