Back Pressure Question
eacyde@gmail.com's avatar
North East Kustoms's avatar
North East Kustoms
I keep popping the drivers side header gasket on my V8 S-10.
I use the Flowtech aluminum gaskets and I have popperd 4 of them on the drivers side.
It is a 355 SBC with Headman long tube headers. The headers have a 2.5" Y-pipe that crosses from the drivers side to the passanger side into a single Magnaflow muffler.
Is there too much back pressure? Would a dual exhaust cure my problem?
bodydropped85's avatar
bodydropped85
maybe, try putting some hi temp silicone(orange) in there on both sides of the gasket and let it cure, mite fix the problem or u need duals.
North East Kustoms
Any particular brand?
bodydropped85
umm whatever the parts store has LOL.
onehot69stepside's avatar
onehot69stepside
Edited: 5/7/2007 7:46:01 PM by onehot69stepside
itll burn off. I use Perc'ys Seal-4-Good and I have never blown them or leaked even after reusing them after taking them apart 4 or 5 times. I can only speak for the head to flange gaskets though. My headers are the flange sealing type and i'd never buy anything that took a gasket at the collector again but i would assume the collector type to work just as well.Check out their xx carbon gaskets also.
http://www.percyshp.com/index.php?option=com_content&task=view&id=5&Itemid=34
North East Kustoms
The gaskets I use are basically the same as the Percy ones. I think a dual exhaust will help my situation.
Thanks for your help.
ScojoDak
Try this
onehot69stepside
they might be similar but i have read somewhere that there are alot of imitations of the percys gaskets. sounds like your flanges are too thin. are they good headers?
North East Kustoms
I didn't really have a choice with the headers. I have hydros and the long tube headers are the only ones that will clear the steering shaft and the cylinder.
The flanges afr a bit thin Maybe 3/16".
I am off to the exhaust shop this morning to make it a dual setup and hopefully it will be a bit quieter too.
I'll post the results.
North East Kustoms
The dual solved the problem. No more popcorn machine sound. it is so much more quiet too.
