allignment
onclemafia@aol.com's avatar
allignment
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
when i get the front end alligned at ride height it'll stay alligned when its at that height right?
detached's avatar
detached
it will be close bro, due to the adjustablity of the suspension (air ride/juice) it makes it difficult to lock into a perfect allignment from what im told
BggdNBdyDrppdJunk
anythings better than what i have going on right now, thanks dude
TOYBOY89's avatar
TOYBOY89
Whenever you come to that height your alignment will be exact to what it was set at, unless you have bent something or have worn out suspension items.
BggdNBdyDrppdJunk
thats what i was hoping to hear, thanks
lunatiksblazer's avatar
lunatiksblazer
so what is everyone setting up for as ride height
BioMax's avatar
BioMax
Half travel. If there are any alignment probs, they will theoretically be only half as bad, at worst, if the alignment is set a half travel. It's a bit hard to explain, but as long as the suspension is decent it works...
thacru78's avatar
thacru78
I had my alignment set tucking 1 inch of tire. Which gave me plenty of room to turn that way I didn't have to air up at every corner. I put 10,000 miles on it in 3 month's and it showed no irregular wear on the tires. Not even a little on the inside from riding low.
