valves?
valves?
scotto79
So I'm finally at the spot to look for valves, I'm probably going to run ASCO 1/2", and was wondering about running either 4 or 8? I want to run just front and back, but would I use 1 for fill and 1 for dump and how is that plumbed in?
LOWEST1's avatar
LOWEST1
I run 8 valves when ever possible. It is better for cornering.
simple-pleasurez's avatar
simple-pleasurez
yep you have to think. if you run 4 valves and you push on one side all the air is going to go to the other side bag. rock like a mofo
scotto79
ok thanks, so does 1 valve plumb into the other? Or wheres a site to get a good diagram at?
minitrukinranger's avatar
minitrukinranger
At least run 6. Thats how many I have. Just put the front on individuals and you can run the back together and still get a good ride.
suckafree's avatar
suckafree
Originally posted by minitrukinranger
At least run 6. Thats how many I have. Just put the front on individuals and you can run the back together and still get a good ride.yep...what he said...minimal of 6 to stabilize itfront2 fill 2 dumprear1 fill 1 dump
dragontoy22r's avatar
dragontoy22r
Go to AIM's website. They have a pretty good foolproof diagram. After looking at that, you'll have a better understanding and you can change it up from there. Search the other forums too. I know I've recently posted that diagram.
toadfrog17's avatar
toadfrog17
scotto79
Thanks everyone, I'm just getting my Ranger rearend today, then the back is getting bagged this weekend if the brackets come in time.
