20's on s10 question #3,346,246,435
sdime2372@yahoo.com's avatar
jumbo's avatar
jumbo
Ok, i'm putting 20's on a 99 s10 ext cab. i want to know if i can keep the battery in the stock location and fit the computer under it and throw in an overflow for the radiator somewhere. Or do i have to raise the battery? Is there any way to keep it there? I don't want to relocate the batt if there's any way around it.
thanks.
suckafree's avatar
suckafree
it can fit in there....but once you turn your tires....it suddenly doesnt work there anymore
suckafree's avatar
suckafree
ah...useless info from me...is it laying frame or body?
DougyFrisch's avatar
DougyFrisch
ditto, missing some key information...
munk3yx
you should be able to keep the battery in the stock location on mine the computer is under the dash but there is enough room ontop of my fender there is i think 3 inch's or so ill get some pics and try to show you
riceeter85's avatar
riceeter85
whats up yes u can keep ur battery in the factory tray i just put my wheels and tires on the front and all the way down its about a half inch away. u just have to suport it from the under side. and about the computer u should put it in the truck u dont have to extend any wires u just run the wires in the cab it thats it... good luck bro...
one_low_s10
Edited: 4/30/2007 6:24:02 AM by one_low_s10
i had to relocate mine to the back of the frame, but i was setup for 22's
jumbo's avatar
jumbo
sorry, laying frame right now, body to come later. but i'm putting in a carbed 350 before the body drop so the computer will be tossed eventually, that's why i don't want to do any crazy placements or relocations, it's just temporary.
sdoord
move it now, batteries are ugly. especially with a blingin 350 next to it. on the positive terminal there are two factory wires. one goes to the alernator the other to a fuse block on the core support below the battery. Run the alternator directly to the block and a single 0 gauge from the block to the new battery placement ground on the frame next to the battery and ur done.
