HELP S10 not geting fuel
ID
I drag
yea pump is not kicking on n ill work on it all day n go back the next day n it will work wtf. i hit the pump but nothing, i fallowed all the wires n they look good.it ran before i BD it but ran like shit would some times back fire r smell gas. help what can i do to get around this r easy way to check the pump or fix it i got a show in a week n this was not on the to do list. thanks george
injunjoe's avatar
injunjoe
its easier to put a fuel pump on by pulling the bed off just have a couple of buds help u shouldnt take a hour to a hour n a half
Lonoma2k's avatar
Lonoma2k
check the fuel pump ground first...its back by the tail light wires on the drivers side frame rail...sounds like the pump is going out tho...there is also a fuel pump relay behind the dash on the pass side (if your wiring is still stock)...check that
jumbo's avatar
jumbo
when's the last time you changed your fuel filter? after mine was in my buddy's body shop for a year and a half, it ran fine for 2 weeks, then it would'nt start. it'd crank and turn over then die. i let it sit, tried it the next morning, no problems. was fine for a week or so, then same thing happened. my fuel filter was clogged from sitting for so long. we started it every couple of weeks or so, but it still got jacked up. i say try that, especially if it's been sitting for a while when you bd it.
bobby king's avatar
bobby king
yea your fuel pump is going out.I had the same problem. Get some friends pull the bed and it's right on top easy to get to and replace. good luck
ID
I drag
thanks guys! by any chance does any one know were that relay is under the dash? i know there the ones that were on the fire wall n i replaced them. also is there a way to hard wire the pump - put power to it to make sure it is the pump n does any one know what wires would be hot?
HeatWaveDave
Originally posted by injunjoe
its easier to put a fuel pump on by pulling the bed off just have a couple of buds help u shouldnt take a hour to a hour n a halfyeah i'll second that...GM fuel pumps kind of suck...but if you need a quick fix just rap on the tank while someone turns it over for you..but you should probabluy change it out hah
GOT FLAKE's avatar
GOT FLAKE
try puttin starter fluid in your air intake. if it starts for a sec then dies its your fuel pump then you have to change it it took me bot four hours i had the same problem i was bout to move from amarillo to austin and day befor it went out
kzeliminator
JUST WENT THROUGHT THIS AND THEN SOME:
1.IF YOU HAVE A BAD PUMP,PULL THE BED TO GET ACCESS TO THE SENDER THEN REMOVE PUMP REPLACE.
DO NOT RUN YET
2. CHANGE INLINE FILTER, LOCATED UNDER D/S CAB CORNER ON INSIDE OF FRAME RAIL
3.STILL NO START, IGNITION CONTROL MODULE UNDER DISTRIBUTER CAP.
4.OIL PRESSURE SWITCH LOCATED NEAR OIL FILTER
5.COMPUTER(ITS CHEAP)
6.SENDER
7.TAKE NOID LIGHT TO INJECTORS, MAKE SURE THEY ARE FLASHING IF NOT REPLACE
8.FUEL RELAY AT FIREWALL, ITS THE P/S SIDE ONE
9.NO MORE FUEL PROBLEMS EVER, UNLESS ITS S LINE
kzeliminator
DO NOT RUN YET
6.SENDER
