06 f150
06 f150
Blazinlow15 avatar
Blazinlow15
Im wanting to get my 06 f150 ext. cab layed out on the 24's i have oin it with 305/35 tires... Im in TN and im lookin for a shop to do it and get a little pricing... The wheels are offset a bit so the control arms and rearend will need narrowing but i want it layin frame on 24's... Any suggestions on pricing or shops??
LittleShopLackey avatar
LittleShopLackey
Master Fabber avatar
Master Fabber
Sounds like a good plan. Check mine out.
Later.
Blazinlow15 avatar
Blazinlow15
Hey master fabber how much that cost to get done or did u do it??
Master Fabber
I did it myself. I have not factored out how much labor is involved because of that. There was alot to do, with the front suspension being the trickiest part of it. If you are just going to lay frame then it shouldnt be to much trouble. The problem lies with the short upper control arm which binds pretty quickly. Im currently setting mine up with a full vertical uniball spindle and longer upper a-arm design. This is al being done for good clearance over the body drop that is coming. Im on 295/35/24 which is only a little shorter that the tire you had mentioned.
