here is my question
miashrnnd@bellsouth.net's avatar
here is my question
yasmany454ss's avatar
yasmany454ss
how do guys paint or seal the back of filler plates like stake pocket holes tail light fillers and all other spots were you dont have acces to the back side? also when i was welding my stake pockets i had a lil gap that i was filler and some wire when into the hole and cant take it out now
project94
you coat the inside with weld thru primer, you can buy it at any paint store/supplier for body shops. as for things falling inside you prolly have to cut it open to get it out
yasmany454ss
u used weld thru primer but that melted...nothing felt inside just a 1 inch welded wire stuck b cuz by mistake it when thru the hole
no1lowr's avatar
no1lowr
its a piece of wire? who cares, dont worry about it, as for coating it, it should have factory paint nside there and that should be enough to keep it from rusting. just get some weld thru primer and go to town
yasmany454ss
WHAT DOES WELD THRU PRIMER REALL DOES IT DO? I THOUGHT IT WAS TO SPRA THE FILLER PIECE BARE METAL AND THAT IT WOULD HOLD THE WELDING HEAT
bodydropped85's avatar
bodydropped85
when it burns it bonds to the metal instead of flaking off.
