compresor problems
johnnievmc@prodigy.net's avatar
compresor problems
steelnutz91toy's avatar
steelnutz91toy
i just finished my bag set up in the front but my compresor will not shut off and i know it dont take that long to fill up a 5 gallon tank. help me out
quit playen, just live life to the fullest
MIDWEST DRAGFEST's avatar
MIDWEST DRAGFEST
do you have a pressure switch? because if you dont you need a 2 position switch to turn on and off a compressor
Rob Clayhill's avatar
Rob Clayhill
pressure switch or gauge?
when my PS went out i also used a switch so i could manually turn it on and off. but having a gauge helps alot
MIDWEST DRAGFEST
yeah it does. it always good to have that back up switch incase the pressure switch goes out which happens from time to time. and the compressor will stay on or not come on what so ever.
steelnutz91toy
yes i have a switch is there a possiblity it could be bad right out of the box
MIDWEST DRAGFEST
could be. factory defect that or it was wired wrong one of the two.
steelnutz91toy
well with two wires i switch them to make sure that it wasnt that. should i changr it out then and go from there?
MIDWEST DRAGFEST
yeah try that. i wasnt trying to say that you wired it wrong just the only 2 possiblities left.
keele's avatar
keele
Edited: 4/13/2007 8:30:08 AM by Layin Low 4 Life
how many amps is the switch you have on your compressor rated for? if you just have a cheapy switch to turn your compressor on and off then you will burn them up all day long. If you get one that is rated at like 50 amps or enough to handle what your compressor is drawing you should be fine
steelnutz91toy
naw its kool i was in a hury to finish it for a show last week so i checked it because u know haow little things could go wrong when your in a hury. hey thats for the help man.
