body drop?
miashrnnd@bellsouth.net's avatar
body drop?
yasmany454ss's avatar
yasmany454ss
sup guys i have a 1990 chevy 454ss that i have had for 4 years and i have not work on it on the last 3 years now ima get back to it.. i whant to do a traditional bd to the rockers.. whats the best way.. i have never bd a truck before o by the way my shops floor is not level.. the truck is only cab no motor no bed doors or interior please help
get twisted's avatar
get twisted
get the truck up on jack stands an use shims to level off the frame front to back and side to side that way you will have a level frame and be able to look underneth where your cutting to make sure you clear all your brake,electrical,and air lines look on like devious kustoms web site to get an idea were to cut the cab there is more than one way to do it so once you see whats going on youll beale to figure out what to cut and what not to
hope this helps you get started and good luck
yasmany454ss
im not sure were to cut tho i will need a pic with the lines marked,,
injunjoe's avatar
injunjoe
http://www.streetsourcemag.com/tech/ViewArticle.aspx?ID=1
i know ur truck isnt a crew cab but this will give u the jist of things, i know u wana do a trad and im sure uve heard this 1000's of time but stock floor is the only way to go but heres some info on a traditional
Marcus
cut down the the side of the floor about half wy up the firewall and about the same on the back wall
dragnbody's avatar
dragnbody
Stockfloor is where its at, But everybody has there own opinion. Go to ifcustom.com, theres some pics on there.
