Best Tie-Down Straps
layinrocker720@yahoo.com's avatar
railn720's avatar
railn720
just wondering what everyone is using for tie down straps when trailering a body dropped truck, been using regular ratchet straps for when i was layin frame, but when i get it back BD'd it will be a lil difficult, so i was wondering what y'all recommend, and yes i know your gonna say just drive it...and believe me i will but there will be some cases where i will be using my trailer...so any suggestions will be appreciated
fkntukn1's avatar
fkntukn1
i haul mine with the ratchet straps and works fine im bd
railn720's avatar
railn720
i was lookin for some good axle straps or something like that
fkntukn1's avatar
fkntukn1
not sure i always use the big ratchet straps and never had a problem, i go under and over the axle
maz duh's avatar
maz duh
Just air it up a bit when you tow and tie it down the same as you do now and you should be fine. If you check a circle track supply shop you can usually find straps for towing that wrap over the tires. If you're rockin a detailed chassis this could be the hot ticket, avoids the potential for accidentilly scratching paint underneath. I know you can put towels or rags underneath you straps to avoid this but stuff happens sometimes... At least with me it seems,lol
SHOWTIME
when i haul mine i use 4 good rachet straps with 4 short straps with d rings that go arond the axle and frame.works like hot dame and never had a problem
79squarebody's avatar
79squarebody
poor cole..u can get ratchet straps with axle straps built it in thats what i use to strap your milk with ..
Pp_Laynbody
Cole, rig up hooks at the front and rear of each tire and tie each tire down... sumbitches will never come loose then...
guiltybydesign's avatar
guiltybydesign
I use D-rings on the trailer with axle straps and these-
http://www.speedwaymotors.com/p/2889,217_Safety-Racing-Tie-Downs.html
