How do you guys get your axles straight on your trucks once you have taken them off? My last 4link had my axle going at an angle which caused problem so i took it all off and im redueing it so how can i make sure the wheel base is right and aligned with the front? Any ideas? thanks
ShakinPlates
measure your lengths on the frame and then use a plumbob to mark the center part on the axle
/7
///RELAXED 720
plumbobs makes great... I get the axle close by eye then measure from common points on the frame to the axle on both sides..then I cross measure from the common points to the other side of the axle..then I measure from frame to wheel or axle backing plate just to double check everything & to make sure its the same on both sides.....hope that helps ya ........
Chevyguy
We did a budies Dakota the past few weeks and I marked where the axle was with the leafs on it with a plumb bob and then used those marks to mark where the axle should be front to back and side to side.
86nissan720
Edited: 3/29/2007 1:18:17 PM by 86nissan720
thanks ill give that a shot, but how do i get the axle in the right length from front wheels to back wheels.. do i just lay it out and make sure the axle is in as far as it can go into the trans?
/7
///RELAXED 720
If I remember right wheel base on the king cab 720 is 110"(center of the front wheel to center of rear wheel) plus u could always sit the bed on the frame & line the axle up that way
