Uni-Balls...for Control Arms whos got'em?
12 following
slamdblazer avatar
slamdblazer
Alright just curious if anyone knows where to buy just the uni-balls and the sleeve they mount in, to use on control arms. any helps great later
jeebus @ mmw avatar
jeebus @ mmw
we got em.
we can sell you them with a custom shaft that will bolt right into your spindle, or you can drill your spindle out and use a grade 8 bolt....up to you.
www.barelylegalfabrication.com
slamdblazer avatar
slamdblazer
Yea im not tryin to drill a spindle out lol, if i dont have too. What do you thinks better? the shaft or a grade 8?
slamdblazer avatar
slamdblazer
ive got BYC arms on my blazer and ive been kinda thinkin about reinforceing them and runing uniballs in them.
jeebus @ mmw avatar
jeebus @ mmw
Eh, i personally wouldnt fuck with the modifying the BYC arms.....that sounds like it could go bad possibly.....
i sent you a reply to your PM, call me tommorrow at the shop and ill take care of all the stuff you need.....ask for taylor.
Taylor
Low_SST avatar
Low_SST
You would typically drill out the spindle for the bolt and crank it in.
HotRodDime avatar
HotRodDime
taylor, a buddy of mine from NZ should be emailing you and i got your email for the mag
jeebus @ mmw avatar
jeebus @ mmw
well, if your not trying to drill your spindle......then the machined shaft to fit the taper of your spindle is probably your best bet. We make them from chromoly high tensle steel, its 28-34 rockwell, the material we use is just as strong as a grade 8 bolt, tensile stregnth is 95,000 lbs psi.
jeebus @ mmw avatar
jeebus @ mmw
werd, im just replying to his email right now!
thanks mike
slamdblazer avatar
slamdblazer
95000 lbs thats it? im looking for like atleast 150,000. lmao jus playin thats crazy tho, umm u probably wont here from me for a couple weeks maybe but will deffinatly be gettin those from ya. thanks for all the help later.
