are the bag cuos for a caprice the same as a full size chevy
jrobles1997@yahoo.com's avatar
gorillagarage's avatar
gorillagarage
got a buddy who want to know so he can use them on his caprice
juicedwagon
that would be info i can use too. anyone know?
cdndragrr
measure how deep the spring pocket is and then measure the top bracket then you'll get your answer
Psycopath's avatar
Psycopath
someone on layitlow said the sd s-10 cups were a direct bolt in for his rwd caddy, which has the same frame as a caprice.
NRskinny's avatar
NRskinny
My guess would be the S10 cups are the same as a Caprice. I know I had a set of Belltech drop spindles on a 91 S10, and they would fit my 72 Cutlass. A caprice should be the samething. But like I said, thats just my guess
phat phabrikationz's avatar
phat phabrikationz
Negative ghostrider on the fullsize cups... Use the 2 in upper cup and flush off the bottom cup with the top of the upper control arm.
juicedwagon
oh man, you said "Negative ghostrider" i though i was the only nerd that said that, not callin yuo a nerd or anything. what cups to use s-10 and cut down to 2'? of fullsize? just wondering the dia the cup has to be. my garage is full right now or i would go take a look for myself.
phat phabrikationz
The diameter depends on what type of tube/pipe u use. I use 4 inch pipe that is 1/4" wall. Or u can use 5" OD tube. The upper needs to be 2" tall just like an s-10.
juicedwagon
sweet thanks, i think i have 4" 1/4 wall at my work too. by the way, jake your caprice is/was hot as hell man, nice work
