HID HELP
sonoma00x@sbcglobal.net's avatar
HID HELP
Hemi00x's avatar
Hemi00x
Alright ive done about 5 install's on 4 different makes and models and im having trouble doing my second dodge ram... The first ram was an 05' and now ive got an 06' the bulb type changes from a 9007 and now its a H13.. Well here's my problem ive cut the stock socket off and wired it up trying all combinations and i can get the lights working fine till i turn the truck on then the 12v wire loses power.. Anybody got suggestions like a relay? Im figuring its a computer issue
slamdxterra
300Cs and magnums have the same problem. U need a lil inline cap for the 12v side. Yah when u start the truck the 12v wire jumps all over from 6v up to 12 and it will make the HID flicker alot. U can also try a relay but its hard to find a relay that will work using that broad spectrum of voltage...best bet is run a lil cap on the 12v wire then run it to a relay. Thats what i did on several dodges that i have done.
