few sdime questions
few sdime questions
Forever Draggin avatar
Forever Draggin
im currently baggin a sonoma, 2nd gen with 2.2ltr to lay out on 215/35/18
can anyone go into detail, or does anyone have any pics that might help me, im wondering what exactly has to be done to save the air conditioner...if anything can save it
also im wondering what are everyone doing about the two bolts under the driver side door on the trans xmember that sticks down? any advise would be appreciated...just want an idea what needs to be done before i get to the front, thankx
I drag avatar
I drag
i plated my control arm's to lay the front out n shaved my heater box n fiber glassed it to keep the heat n so on you will need to cut the inner fender n not shore with that tire size but i had to notch for my tie rods
good luck if you need pics i.m. me at one2accelerate@aol.com
rrusd avatar
rrusd
You won't have to noth the tie-rods with those tires. I cut, and used ABS plastic, rivets, and a lot of caulking. I t lasted for a while, and then my passenger side valve stuck, and let the truck drop HARD at 50 m.p.h. destrying the box from the hit lOL. Since then I have bodydropped it, and have no heat or A/C. I am going to get an aftermarket A/C soon.
afrofromDO avatar
afrofromDO
as far as the two bolts go, just flip em. I know that Little Shop of Horrors made some brackets to retain the factory AC as well as moved the battery tray and also relocated the fuse box underneath the battery tray, it was some really good work
