looking for info on hydro's. how they work? how to keep them in good shape? oil to use? how to hook them up(wiring)? there manitance? pro's and con's about them? any help thanx.....
juicedwagon
check out www.layitlow.com they have a great tech section. thats where i learned a lot of my hydraulics info
rockin94astro
thanx wagon. great info there....
dragnram
make sure you use non-detergent oil also
dragginncrds
anything you need just IM me on AIM at dragginNCrds or e-mail me at bigwills@ec.rr.com and i can help with any questions u have
juicedwagon
i use hydroulic fluid from autozone. i used non-detergent at first and its not as nice as the hydroulic fluid. i figure its at autozone and real easy to get so i swapped over and it acts a lot better, doesnt foam. you will love hydros
rockin94astro
question. i lefted the ride up all the way and about 3 or 4 hrs later the front driver side was on the ground. any suggestions? and how to fix it?
3 wheel on 20s
check your check valves. a way to check it is to lock it up all the way and close the slow downs all the way off, if it still falls then you have bad o rings in the strokes. if it stays locked up then you have bad check valves.
