rx 7 rear ends
rx 7 rear ends
b2low
i want to see pics of minitrucks with rx 7 rear ends, and how they look up and dropped!! please, prefer mazdas thanx
lowridermags's avatar
lowridermags
not to jack the thred but if anyone knows if this is true?...
i heard that the drop out differential gears in the mazda rx 7 boult into the mazda b2200 2wd differential??? can anyone conferm that?
TwistedMinis's avatar
TwistedMinis
Dude the differential is way different. Lol.
baggedhb
my nissan has one under it....narrowed 1.5" per side tho
http://nissancustoms.com/album_pic.php?pic_id=576
dssur's avatar
dssur
only the housing, the third member design is essentially the same.
Look on mazdabscene.com, there is a tech article on putting 2nd gen RX third members in mazda truck axles. You only have to mod the housing if you have a 4x4 mazda. In every case you have to have a driveshaft made because the nose of the RX diff is a couple inches longer.
dssur's avatar
dssur
Originally posted by iLLblazer
http://www.streetsourcemag.com/ViewOwnerProfile.aspx?Home=true&ProfileID=40644
I love the idea of using the pre bent rails. Enough that I am doing it to my S10.
impulse's avatar
impulse
Copy Cat!!! hahahahaha.
