I've seen and heard of setups running dual fill or whatever... how do these work? can u used dual dump too?
i know the purpose is just to get more air into the bag quicker... but how?
N
nvrlowenuf
i've heard it helps to have dual port bags...and yes they can be used as dual dump as well. it works both ways it just all in the plumbing.
laydoutb26
i knew the dual port thing... but how is a dual fill setup setup plumbed
gslif
4 valves at each corner. 2 on each port. 2 fill 2 dump.
515customs
Its plumbed the same way as two valves. but you do it two times for each bag.
laydoutb26
thought so... and wiring? just doubled up to the switch?
str8azztaco
your best bet is to draw it all out on paper, you'll prolly want to wire in some switches to just 1 set of the valves too
str8azztaco
thacru78
I would see the purpose for dual fills but I don't think you need dual dumps. I have my 3/8 valves reduced to 1/8 and it drops way faster than I like. I have to feather it down or it will smash the ground. Definately dual fills but I think you would be wasting money using 2 dumps.
laydoutb26
thanks for that jerry... i think i will run dual 1/2" fills on front... it'll be a FB setup though... i don't need individual wheels...
