Not running a booster
BT
ben thorne
Anyone running or thought of running Triple Master Cylinder Pedal Assemblies from wilwood? Just wondering if they would be any good in the truck.
http://www.wilwood.com/Products/005-PedalAssemblies/002-FSMP/dual/index.asp
ThanksBen
LOWEST1's avatar
LOWEST1
It will work great as long as you get the correct master bore size for the brake callipers you are running. Since there is no booster you need a larger bore than stock, you will also most likely have a stiffer pedal feel. Not as comfortable for every day driving but still can stop on a dime. Hope this helps.
BT
ben thorne
This may sound like a stupid question but how do you work out what master bore size I need.
Thanks
Ben
