Just bought Cylinders...
RedNinety5 avatar
RedNinety5
I just purchased 2 3" Parker Cylinders. I was just wanting to know what the three ports on them were for. They have 1, 1/2" port on the top, and 2, 3/8" ports on the side. If someone could help me out with this asap it would be great. Also, if the 1/2" port is for the airline coming from the valve, how the hell do I attatch it if I have it mounted to the car? Just drill out the tower to accomodate a fitting in the middle? Btw, it's the front of a 95 camaro.
Thanks!
kevin@aac avatar
kevin@aac
well more than likely you are going to use the top 1/2" port for your fill. Plug the upper 3/8" port on the side. The lower "breather vent" add a flat filter in it to keep dirt and dibris out, so it dosnt screw up the seal or score the can. Hope this helps.
RedNinety5 avatar
RedNinety5
Okay, yeah,i just found that out from the company I ordered them from. Now, question is...where can I get a filter?
forbidden avatar
forbidden
Hit me up bro ill send you 4 of them for $5sales@fmkustoms.com
