hydroboost setups
hydroboost setups
granth
Edited: 2/18/2007 7:10:56 PM by framedragger
anyone got pics of theirs? looking to add power brakes, and want to do it this way instead of the big and bulky ugly way.
Do you guys hide the actual unit and master cylinder or what? Pics would be perfect.
SparkinBlazer
umm, your question is a little misleading...you say u want to add powersteering but a hydroboost is for power brakes...dont have any pics of this setup but officer farva had a hydroboost setup in the blazerado if you can find pics of that
granth
my fault I typed it wrong.
minitrucker69
Check out the new truckin my 2006 has a close up pic of mine
LOWEST1's avatar
LOWEST1
Sorry I dont have pics of my setup. But it came stock on my 89 Chev crewcab dually. The power steering pump 2 return lines. 1 from the hydro boost the other from the steering box. I would think that you could "T" the return lines together. They work really well. My only complaint is that when my power steering pump went out I had no brakes pulling the trailer. Hope this helps a little
granth
I plan on pulling one out of another car, not buying one. I believe Astros had them. I will probably look for it in one of those as they are pretty common in the yards here.
dssur's avatar
dssur
I know s10 guys use the astro stuff because it bolts on, but I will mention some older BMW 5 series had a hydroboost system, and best of all the clutch master mounts inside the firewall. I am going to use the whole pedal assembly on my s10, solves two problems at once.
granth
Hmm...that could be an option as well. Do all of them run through the power steering pump, or no? My truck doesn't have power steering....thats not by choice, but reguardless, it doesn't have it. I would rather ride around with no power steering and power brakes, rather than the opposite.
incognito 1's avatar
incognito 1
yeah astro van setups. are the easy cheep route..
incognito 1
sorry for my bad typing lmfao
