Viair and Air Zenith
suthrn98@aol.com's avatar
low mazda's avatar
low mazda
I got one Viair 400, and I also have only a 145-175 pressure switch. Would I have a problem hooking up an Air Zenith compressor with it. RUn both off the same pressure switch. I know I won't be getting all I can out of the Zenith, but I just want my re-fills to be faster.
Also, do Zenith's ahve a check valve like the Viair does?
TheMansPuppet
It will work, you need to use relays or Ford type Sol.
Rambo
Ford sucks, get a continuous duty one for a plow or something, those are the better ones.
low mazda's avatar
low mazda
this is the relay I got. Can I run both compressors off one of these. It's 100 amp continuous.
forbidden's avatar
forbidden
Yup you can no problem...
Hc Daytona Dragger's avatar
Hc Daytona Dragger
Not to jack your thread Blitch, but I have a question... would running a continous duty Solenoid with 2 compressors be good enough, or should I run relays also
