uniballer help
Twotipped@aol.com's avatar
uniballer help
Low_SST's avatar
Low_SST
I wanted to get some feedback on my plan, I want to get a 1" uniball and to install it in my upper djm arms i want to drill and then ream out the current balljoint cup so i can drop in the uniball cup then i will tig weld it on the top and bottom edge to tie it to the existing cup and i will also do some 1/2" rosette welds front and back.
Does this sound like a good idea? Does anyone have any experience with these and can you recomend any hardware or installation tips, what ever.
Low_SST's avatar
Low_SST
speed bump
BioMax's avatar
BioMax
I'm not quite folowing what you are asking, but if you want to replace the upper ball joint with a uni-ball, go ahead. A 1" uniball is absolutey overkill! TrophyTrucks do 160+ mph across the desert with 1" upper uni-balls, you can easily use a 3/4" or 7/8" uniball and get away with it. The 3/4" uniball will offer the most angle (32 deg) with a 1/2" bolt.
If you can, post some pics of what it is you are trying to accomplish.
Low_SST's avatar
Low_SST
this is what my current djm upper arm looks like. The reason im gonna drill out the balljoint cup is to keep everything concentric with out using a jig to locate everything. My buddy said he was rocking the 1" uniball with the belltech spindles but i suppose i could go 3/4 and then if the hole in the spindle is already too big because of the taper i can alwayys ream it and press in a bushing of some sort to bring it back to the dimension i need. Can ya picture what im saying? I just want it beefy enough to handle the stresses of the rams upper balljoint angle as well as not bind up on me. Plus its cheaper then a damn balljoint for a ram.
BioMax's avatar
BioMax
Yeah, that makes sence. There is no reason that it wouldn't work.
"if the hole in the spindle is already too big because of the taper i can alwayys ream it and press in a bushing of some sort to bring it back to the dimension i need"
Exactly...
Low_SST's avatar
Low_SST
Hey Max if im reaming the spindle for a bushing do you think i should do a slight interference fit and then heat the spindle and press the bushing in or will that cause too much stress once it cools?
