I just bagged the front of my 89 blazer and the dump vavle sounds like its getting stuck open or some shit. its a new vavles anyone got any helpful hints to fix it.
dakotamike
what kind are they most of them if you break them down to the diaphram you can stretch out the spring cause they may be worn out what kind and how old are they anyway ? or you can buy a rebuild kit too
dropedtrk13
the are gc 250 xtreme vavles and the are new bought them like 7 months ago for my ranger and never used them
twistedsdime
Are you sure you hooked them up right?? If you did them just check to make sure they are clean. Some times trash come get stuck in there and cause the valve to get stuck. or example if the bag is lifted and you try to drop it and all it does it keep picking itself back up. Or this past week it has been a little cold around here and has caused my valves to not want to work until they warm up. I hope this helps some.
BAGD RANGER
THE VALVE SOUNDS STUCK -- IT HAPPENS ON MINE ONCE AND A WHILE --- WHAT I DO SINCE A RUN NITROGEN IS A LOWER THE PSI GOING TO THE BAGS --- HOPE THAT HELPS !!!
