2 valves per corner or just 2 for front, 2 for back
MP
mike payne
Edited: 1/31/2007 2:29:31 PM by mike payne
i was fixing to get new valves for the front i was going 2 put 2 valves for each corner would it be better to run a airline from tank to each corner or just tie both fill valves together and have 1 airline .please help quick.
MIDWEST DRAGFEST's avatar
MIDWEST DRAGFEST
well what size valves are you runnin? and how fast do u want it to be
olskoolpup
i reccommend 8 valves for sway and body roll control. even if you onlyr un 2 switches
the only way id run 2 valves teed to one end is if its in the rear of a 2 linked vehicle. w/ a 2 link the pressures in the bags need to be the same or there will be binding issues.
MP
mike payne
they are 1/2 gc 450's i want it to be some what fast its a 86 chevy fullsize. would it be best to have a line for each corner.
get twisted's avatar
get twisted
RUN TWO LINES FROM THE TANK AND YOU WILL BE ALOT QUICKER THAN ONE YOU WILL BE PULLING TWICE THE AIR VOLUME FROM THE TANK
no1lowr's avatar
no1lowr
Originally posted by 86IsuzuPup
i reccommend 8 valves for sway and body roll control. even if you onlyr un 2 switchesthats all i run
shitty
depends on how fat you are???? with a 4 valve setup your truck will lean and also depends on the gas tank( what side it is on. I always run 8 valves because body roll sucks and i am fat
nryota's avatar
nryota
i have 1/2" gc's....each corner has an individual feed line to it, i know its a small truck but its quick as hell
TukinRange
a valve on each corner will be your fastes bet, I'd say you can just T an airline into a set of valves to fill the front, but i wouldnt recommend that unless you HAVE a swaybar still cause that bodylean gets super scary. Especially on the highway
MP
mike payne
thanks yall,im going with 2 per corner.
