Paralell* 4~link ?'s
Z
PazzFlaMazda
ok im puting on a 4-link everythings going good but.. I want to shortin the panhard bar so i can put on top of the pumpkin .. does that make any sense?
If not anyone have any ideas ?
dssur's avatar
dssur
how much lift do you have? because a short panhard will pull the axle side to side more than a long one.
PazzFlaMazda
im going to use a over axel or behind axel bracket "depends on panbar" Im useing an Re8
so ... 10 inches of lift That will not work will it ... darn any ideas?
MF
Master Fabber
Why dont you keep the panhard bar long and make the behind axle brackets-become front axle brackets? Will this work?
dssur's avatar
dssur
good idea!
I have an idea too, why not just leave the panhard as long as it is and put it over the axle anyway. Just make the mounts longer so it clears the pumpkin.
///RA TROY's avatar
///RA TROY
run a watts link
balcar's avatar
balcar
If you have tire clearence u can do it, but its allot better to do a longer bar. Worth the extra time to do it right.
PazzFlaMazda
Thanks alot everyone i think im going to put the bags behind the axel it seams to fit better .. i went out to the truck and that looks ok.. i hope thanks agin
