trouble boltin body on..
canadian4_life2003@yahoo.com's avatar
86nissan720's avatar
86nissan720
Ok i did a SFBD and when puttin my cab back on of my nissan 720 three corners under the cab bolt down fine except for the fourth one. the driver side corner needs to go down about a half inch but i cant figure out what is holdin it up.. anyone ever have this problem? any ideas what could have happend?
rizz0's avatar
rizz0
get under it something is hitting!!!!! prob a hang down off the floor, just fit what it is and either cut it out and raise it or massage that part with a hammer
TwistedMinis's avatar
TwistedMinis
Get another friend, have him stand on the other side of the door sill, and jump on the side that won't go down. Mine needed a little bit of persuasion going on. Took some force but it all eventually came down. It had ot go on in a certain order, so you may have to lift one side up and put the other side down first.
lowdyme's avatar
lowdyme
is the new frame level? or try bolting the corner first and then do the coner opp. and go like that
86nissan720
thanks ill try boltin it in a different order
TwistedMinis
Also try not bolting them all in. We got the cab all the way down on the mounts before bolting anything down.
twistedsdime's avatar
twistedsdime
I'd say screw it and just leave it alone. HAHAHA
dssur's avatar
dssur
I had this problem after sfbd my mazda, turns out my long ass seat belt bolt on that side was hitting the exhaust pipe. I was amazed that the thin walled exhaust tubing and that one bolt were holding the whole cab up.
Forever Draggin's avatar
Forever Draggin
i had this problem when puttin my f150 cab back on for the first time, nothing was holding it up, the frame was level, couldnt figure out why. but eventually it went down. just dont tighten the other bolts all the way first just thread it once and move on to the next, and i would personally start with the corner thats giving u trouble...good luck bro
