fiberglass sub box
fiberglass sub box
yellowranger avatar
yellowranger
i built a box had it all done and fell off work bench has 3" long crack in it glass is about 1/4" thick. how do i go about repairing it? any help? thanks
Twisted Galant avatar
Twisted Galant
I would start out grinding away at the cracks. Kinda gouge (SP) them . Then reinforce the front and rear of the spots where it cracked
low99maz avatar
low99maz
Like jason said grind away at the crack then use some mar-glass or tiger hair.
What did you use to polish the intake and pulley brackets?
jdauer02 avatar
jdauer02
check out www.fiberglassforums.com its a great fiberglass community.
yellowranger avatar
yellowranger
thanks for the advice and links.
the intake and pully brackets i used a dremal and d/a sander and alot of hand sanding and a buffing wheel in a die grinder
took about 90 hours but came out sweet.
i have the steering pump brackit and a/c compressor not using them any more if interested let me know
e-mail yellowrangeron20s@yahoo.com
JRS KUSTOMS avatar
JRS KUSTOMS
stop! drill a hole on each side of the crack where it ends then grind a small dish all the way down the crack fill it with glass mat and resion then finsh it off with bondo or duraglass.this will keep it from cracking when the mad bass hits.
yellowranger avatar
yellowranger
thanks that is what i did hopfly it will hold again thanks.
