Brake Booster and Master cyclinder?????
TuKnRaiL avatar
TuKnRaiL
After looking through the chevy truck forum I have a question about the booster and master cyclinder on an 03 sonoma. Well after tubing the firewall and jacking up the tire up to where the truck is going to lay out it appears that a 7" booster is still going to hit the tire. The truck has 22x9's on it. What are some options for this application?? Any help will be greatly helpful.
lowdyme avatar
lowdyme
you could run a hydro booster or you can just take the booster off totally and get a pedal assembly from and older vehicle
TuKnRaiL avatar
TuKnRaiL
Where is the best place to buy a hydro booster????
dubDyme avatar
dubDyme
you could also run a remote booster...and mount it practically anywhere. you could flip it and mount it under the dash. if im not mistaking, you can use a hydro boost from a newer gm....
DRAGNASS avatar
DRAGNASS
www.deviouscustoms.com sells hydro-boosters but they are expensive. and you have to call them for info
TuKnRaiL avatar
TuKnRaiL
Ended up getting setup with Hydratech as a dealer to sell the Hydro-Booster!!! So if any one is nneding one hit me up and I can get you one!
sdime22s avatar
sdime22s
how much for a 98 dime?
twistedsdime avatar
twistedsdime
Hey chris let me know how much for a hydro booster?
mmautoworks avatar
mmautoworks
go to the junk yard and get one if you get one off a super duty with the master cyl all the brake lines come out on the right side of the master so if you are gooing really big you wont even hit your lines but you can get a good one cheap they are not real prone to going out. if you want to put your brakes sideways under your dash and even your clutch look at kugel komponents they carry the pedal assys a little pricy but worth it for the look and the quality of the parts
