Repositioning Balljoints
732kustom avatar
732kustom
Edited: 12/29/2006 7:21:15 PM by 732kustom
hey guys, well im running 3/4 ton a arms on my fullsize with some modded lowers. The upper a arm balljoint is binding up, keeping the front from laying, trucks on 24s ...Should i place the balljoint into the spindle lay the frame on the ground, and then go about my measurements to reinstall the balljoint on the arm. I know a couple guys on here rolling on them 4's.....not down for buying anybodys aarms
beyond static avatar
beyond static
I kept my factory 88-98 1/2 ton arms, and made a slice behind the balljoints, leaving the middle 1" of the control arm still attached. I bent the arms where I made the cut about 10 degrees, and welded them back up. I'm on 22's though.
732kustom avatar
732kustom
thank for replying bro, love the truck....could you send pics, applegarth@earthlink.net
kotalaynframe avatar
kotalaynframe
i have the 3/4 ton arms and ball joints with a reamed spindle an i just did a v cut on the arms and bent them and welded them back up and on my lowers i just cut the sides of the arms and bent them and welded them back up its pretty simple
732kustom avatar
732kustom
makes sense.what size wheels are you runnin fransisco?
kotalaynframe
i dont have them yet but its set up for 32 inch dia
beyond static
damn, you don't play around. lol
732kustom avatar
732kustom
thanks guys, just did the lowers tonight, uppers hopefully tomorrow after the metalyard
