Question about s10 rearend....
jimmyneeld@sbcglobal.net's avatar
ALL 20S's avatar
ALL 20S
I just recently bought another LUV truck w/a Buick v6. It also comes w/a s10 rearend. My question is what will I have to do to be able to use the s10 rearend so I can run my 17" escalades?
91 drggn dime's avatar
91 drggn dime
yes, the s10 rear end is not 6 lug. if you're dead set on running eskies, you'll need to get it redrilled to 6x5.5
ALL 20S's avatar
ALL 20S
would you happen to kno where I could get this done at? Also, you happen to kno how much that would cost? Thanks!
91 drggn dime
any machine shop will be able to drill out the drums to 6x5.5 ... As for the cost, I am not sure of that, no. also make sure that the bore size of the eskie rim is big enough to go over the center of the drum. take a tape measure to both, it should be big enough though.
