Baggin a 94' 4x4 s-10
Lance696
i was needing to know what all i had to do to bag tha bitch up front. . thanx guys laterrrrrr.....
F
FlawlessFab
you got to ditch your torsion bars and you can run your bags off the top of your upper control arm then build a hoop with the bags upper mount ...but you will need to remove the inner fender to do so ....or you can remove the half shafts and torsion bars and shocks and run a hydraulic cylinder....i did that on a 4 door jimmy that i converted to 2 wheel drive and ran juice on ...worked great ....alot of camber on 4x4 when layed out...
