frames
frames
4
4doormazda
im wanting to build a full frame for my truck want to run a irs im just dont really know how to do the front end im kinda lost i dont know if i should do a front clip i would rather do a full frame but i dont know how to make the front end straight and what arms to use and spindles... thanks for the help anyone....
TwistedMinis's avatar
TwistedMinis
If you don't know how to comfortably build front suspension, you should start with a clip for this frame and go from there. After you've built a frame, and seen how the front suspension works, read up on suspension design. There is a lot to it. You have to take into account your arm geometry and how it will affect camber and castor. Also your steering has to be setup correctly to get minimal toe in or out, and to get correct ackerman.
