layin out
layin out
W
wooten1027
What do you have to do to lay out a 94 s10 with a 25.315 in tire??
lowdyme's avatar
lowdyme
if it the stock 15`s you have to tub the fire wall remove inner fenders front and rear trim frame for lower control arm trim spring pocket notch the frame in the rear you have to re route the exhaust because the y pipe hangs below the frame and weld your tranny crossmember on the driver side because the head of the bolts are lower then the frame
W
wooten1027
no it's not stock 15's i was actually looking at a 225-30-20 the diamater is 25.315
AnotherPinkDime
only diffrence is you may have to watch out for your brake booster or get a smaller one
lowdyme's avatar
lowdyme
my truck is set up for 20`s that are 26.5 and i didnt have to move my brake booster so you should be alright mines a 96 not to much changed just becareful with all the wiring that runs over the tires its a real whore if you mess it up
