ARC vS Mig
17 following
dragwithme@sbcglobal.net's avatar
ARC vS Mig
dragwithme's avatar
dragwithme
wut would be better to weld on a frame or weld up a frame... and which is cleaner!!!
Rambo
i would go in this order...
tig...hard to do, can produce more consistant penetration, takes forever to do, can look really clean because the amount of filler is limited by what you choose to add.
mig... looks clean if welded right, good penetration depends on amperage of welder and isnt adjustable, flux sux but burns hot.
arc.. blobby and fugly but good penetration, perfect for heavy equip where looks dont count
bodydropped85's avatar
bodydropped85
Edited: 11/27/2006 5:40:49 PM by bagged85
last time i checked, the heat setting(amperage) was adjustable an mostly ALL welders(tig/mig/stick)
i can lay an arc weld bead just as good as a mig, only down fall is the slag from the electrode coating on top of the weld.
BUT mig always looks the best IMO.
Rambo
you know what i meant, on tig you have a heat setting on the machine and then you can adjust it with a foot or hand trigger, mig has just the machine heat setting and cannot be adjusted while welding.
Rambo
i would say a good tig looks better then a good mig due to the control of the penetration and the minimal amount of filler.
bodydropped85
heli arcin is the bomb.
adjustable while welding no but adjustiblity yes.
olskoolpup
in the hands of a decent welder, there will be little difference between mig and stick.
stick usually has a deeper cut, but you have to chip the weld to get the flux off.
mig will produce a clean strong weld, when an ample sized machine is used.
i mig everything. just what i have experience with.
impulse's avatar
impulse
I'm a mig guy... arc is for the cave men.
N
NaviGangsta
MIG it
but ARC is hellaciously handy in hard to reach corners, behind shit, etc ... just bend the rod in a funky shape and go to town to get around corners.
bodydropped85
also if your bagging your truck ina windtunnel.
