Need help right quick, removing inner fenders on my S10.. I need some pix.
gtsporty@gmail.com's avatar
Brill's avatar
Brill
Edited: 11/26/2006 10:00:33 AM by Brill
I need some pix of where & how you guys relocated, braced or whatever you did to the stuff that is on top of the inner fenders.. My truck is a 2001 5spd 2.2L if that makes a diff..
Also, any pointers would be nice =)
Ive got 18x9s
91 drggn dime's avatar
91 drggn dime
abs is ditched by tee'ing the front lines together and putting a union on the rear line.
ecu wires are extended so you can mount it behind the core or put it under the dash and extend wires out to where they need to go.
ditch washer fluid bottle and order an overflow bottle or use a plastic bottle for temp.
as for battery.. my battery in my first gen, the tray held with the bolts on the core and side of fender, i just unbolted it from the inner well.. u might leave yours or move it.
now unbolt them and they come out.
TEEBAGGINNN's avatar
TEEBAGGINNN
Unwrap the loom on both sides, the computer will extend to under the batter tray without extending any wires. The only wires I extend is one for the drivers side horn and three for the fuse box to move it to behind the headlight. I move the abs to infront of the brake booster.
I have done 7 S10s 2.2 and 4.3l, they are very similar.
Brill's avatar
Brill
Thanks guys =)
