Air Ride Suspensions \  Watts Links ... pros and cons
Air Ride Suspensions Q & A
views 1321
replies 8
following 7
draggingtb   +1y
ok, i'm thinking of running a watts link on my sonoma when i redo the backhalf here shortly. mainly for the look cause i know little about them. so before i get myself into a big problem, what's the good and bad sides to these? i've heard all the good and bads to 2, 3, 4, 5, forward and reverse, etc. set ups, but nothing on the watts. so any info helps. thanks.
CHOSN1   +1y
have you done a search on here about watts links? there are 2 floating around here.
NoMotiv 1500   +1y
I just put a watts link on a friends avalanche i bagged and it works great, the clearance on the tires from the fender (side to side) is within a half an inch and when he corners low it doesnt even rub. I liked the performance so much, i ordered one for my truck. If there are cons, we havent noticed them yet. He gets great height also.
BioMax   +1y
I'm not sure what the other threads say, but...
The pros are that the watts-link has a fairly low roll center (good for handling) and doesn't pull the rearend from side to side
The cons are that they limit travel (depends on the arm lengths) and finding a good mounting point can be a little complicated.
chevygurly   +1y
Edited: 11/23/2006 9:16:05 PM by ChevyGurly
thats the problem with mine...
try a wishbone link or a KP link....most fullsizes use the watts link
dirkbelt   +1y
i have a track bar on mine and it is the shit,i like it alot and keeps the rearend straight at any height,it goes from the hanger on the pass side to the end of the drivers link,mind 2 metal did it u can check it out on their site
www.mindtometal.com
draggingtb   +1y
yeah, i searched the other 2 but they didn't really point out any good or bad points. one was "what height to mount" and the other was "who sells". i can deal with the travel issue, so it looks like i'm gonna be using one on the sonoma. thanks guys.
bdroppeddak   +1y
you can build them to get over a foot of lift...
BioMax   +1y
No way! You'll never get more than 11 7/8" out of it!
