What to use for gas door hose?
Rb7604@gmail.com's avatar
Bigrick31's avatar
Bigrick31
Ok basicly got a fuel cell with about a 2 1/2" spout on the end for a hose to attach to. so i need somthing a little more plyable than the stock hose that runs from your gas tank to your fuel door. im relocating the door to the insede of the bed so i need something that i can bend easily but will still be reliable enough to hold gas.
Jance Customs's avatar
Jance Customs
There are certain kinds of hoses to use for gas lines. Just don't use a radiator hose...
Bigrick31's avatar
Bigrick31
yea but if they are like the stock hose it will kink if you put to much bend in it. but say if i got to a kraigens or somthing they may have a more pliable hose thats rated for gasoline?
bodydropped85's avatar
bodydropped85
napa sells fuel filler neck hose.
Bigrick31's avatar
Bigrick31
buddie of mine gave me another idea. flex exhaust hose! should work i beleive. seems like the best solution at the moment.
complexdesigns's avatar
complexdesigns
No, only use fuel line!
BioMax's avatar
BioMax
They don't have flexible fuel hose that big. You are going to have to use metal tubing to get around everything and use straight hose to connect it all. Make sure to ground the metal hose to avoid static electricity.
mindlissmetalfab's avatar
mindlissmetalfab
http://www.mcmaster.com/
search for fuel hose
not sure if they will sell small quantities to individuals or not. I deal with them through work.
